Easy Prototype Board for SOIC8/MSOP8/SOT23-3/4/5/6 Packages
- Rajkumar Sharma
- 148 Views
- easy
- Tested
- SKU: EL126160
- Quote Now
This is an 8-pin SOIC/MSOP/SOT23-3/4/5/6 prototype board. This is a blank PCB that allows the operation of many chips from various manufacturers. Each device pin is connected to a pull-up resistor, a pull-down resistor, an in-line resistor, and a capacitor on VCC. All pins are provided with a male header connector.
Note: Example schematic of temperature sensor LM35 provided.
- Supports 8-pin SOIC package
- Supports 6-pin SOT23-3/4/5/6 (TSSOP) package
- Supports 8-pin MSOP package
- All Resistors and capacitor Size 0805
- Each device pin has a footprint for an optional pull-up resistor, a pull-down resistor, In line resistor
- 2 Pin Male Header connector and power supply filtering capacitors
- PCB Dimensions 39.21 x 30.00mm
- 4 x 2.5mm Mounting Holes
Schematic
Parts List
NO. | QNTY. | REF. | DESC |
1 | 1 | CN1 | 2 PIN MALE HEADER PITCH 2.54MM |
2 | 2 | CN2,CN3 | 4 PIN MALE HEADER PITCH 2.54MM |
3 | 1 | C1 | SMD CERAMIC CAPACITOR SIZE 0805 |
4 | 24 | R1-R24 | SMD RESISTORS OR CAPACITORS SIZE 0805 |
5 | 1 | U1 | MSOP8 |
6 | 1 | U2 | SOT23-3/4/5/6 |
7 | 1 | U3 | SOIC 8 |
Connections
Gerber View
Photos
Video
LM35 Datasheet
Login
