Electronic Toggle Switch
Description
This circuit is based on CMOS CD4013 Flip Flop IC. It has two stable states, ON and OFF. Once it is ON, it remains ON till you press the switch again. A short button press of a tactile switch SW1 latches the circuit ON and another toggles it back OFF.
Relay switch contacts can handle high AC Voltage as well as High DC current, this makes the project suitable for applications like ON/OFF Fan, Light, TV, Pump, DC Motor, any electronic project that require electronic toggle operations, and a few other devices work on AC voltage up to 250V AC or DC current up to 5Amps.
Applications: TV, Audio Equipment’s, Radio, Fan, Pump, DC Motor, Electronic Projects ON/OFF
Specifications
  • Supply: 12V DC
  • Current: 60mA
  • D1: Power Indicator
  • D3: Toggle State ON or OFF indicators
  • CN1: Supply Input
  • SW1: Toggle Operation
  • PCB dimensions: 45.72 x 57.79 mm
Schematic
003_Schematic
Parts
003_Bom_th
Photos
Gerber View
CD4013 Datasheet
PCB
4 Comments
akkermans
can i order this
Senthil
Dear Admin, is this electronic toggle circuit/switch available now? Any way of connecting with you directly for requirement?
RELATED PROJECTS
TOP PCB Companies
