002.jpg - Electronics-Lab.com
42
Heat Activated Cooling Fan Controller
[Customadds id=643821] Heat activated cooling fan controller is a simple project which operates a brushless fan when the temperature in a particular area goes above a set point, when temperature return normal, fan automatically turns off. The project is built using LM358 Op-amp and LM35 temperatu... Read More
