High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002
[Customadds id=643821] This is a high accuracy current sensor project build using ACS37002 IC from Allegro, which is a fully integrated Hall-effect current sensor with 0.85mOhms integrated conductor. A fast overcurrent alert output, programmable gain settings and analog linear voltage outputs are... Read More
- full (1453x410)
- medium (850x240)
- medium_large (640x181)
- large (640x181)
- 1536x1536 (1453x410)
- 2048x2048 (1453x410)
- re_large (783x410)
- menu-24x24 (24x7)
- menu-36x36 (36x10)
- menu-48x48 (48x14)
- sendpress-max (600x169)
- woocommerce_single (600x169)
- wp_rp_thumbnail_prop (150x42)
