High current bipolar stepper motor controller
- Rajkumar Sharma
- 21.746 Views
- medium
- Tested
- SKU: EL34563
- Quote Now
Description
High Current Bipolar Stepper Motor Controller kit is based on chopper drive. Chopper drive is a method of providing a constant current source to a device. Chopper drive allows for use of higher voltage power supply for better performance and higher speed. It is uses SGS Thomson’s L297 and L298 controller IC’s.
- Logic supply – 5 VDC @ 300 mA
- Motor Supply – 8 to 30 VDC
- Connection via 10-pin Box Header for easy interface with any microcontroller development boards
- External or internal voltage reference option via jumper
- Onboard preset for current adjustment
- High speed switching diodes for L298 IC protection
- Power-On LED indicator for both the supplies
- Power Battery Terminal (PBT) for easy supplies and motor connection
- Heat sink included
- Four mounting holes 3.2 mm each
- PCB dimensions 74 mm x 71 mm
Schematic
I am interested to procure the High Current Bipolar Stepper motor controller. Can you link me to the relevant site ? Thanks
Please check on http://www.koteq.com for kits of our projects.
