High Current/High Voltage OPAMP with Boost Output Current Greater Than 1A
- Rajkumar Sharma
- 4 Views
- medium
- Tested
- SKU: EL150179
- Quote Now
This project provides High Voltage and High Current output swing. The board is built using OPA454 OPAMP and 2 x high current NPN/PNP BJT Transistors. Output transistors Q1 and Q2 provide positive and negative output currents to the load. The project works with an input power supply up to +/-50V DC. OPAMP Vout swings from +47V to -48V and OP output swings from +44.1V to -45.1V at 1A. Connect the J1 jumper to GND (EC Middle Pin + GND Pin) to Enable the output.
The output can be independently disabled using the Enable or Disable Pin that has its common return pin to allow easy interface to low-voltage logic circuitry. This disable is accomplished without disturbing the input signal path, not only saving power but also protecting the load.
Test is conducted with Dual +/- 25Vdc Power Source, Load 10/5W Ohms Resistor, Input +/-1V, Output +/-1A Dual 23V DC (Approx.)
- Power Supply +/-50V DC (Range +/-5V to +/-50V DC)
- Output Current Swings 1Amp
- Output swings from +44.1 V to –45.1 V at IL = 1 A (Supply Dual 50V)
- Input +/-1V
- Independent Output Disable or Shutdown
- 4x4mm Mounting Holes
- PCB Dimensions 76.20 x 29.37 mm
Applications
- Servo Drivers
- Test Equipment
- Transducer Drivers
- High-Voltage Compliance Current Sources
- General High-Voltage Regulators and Power
The OPA454 device is a low-cost operational amplifier with high voltage (100 V) and relatively high current drive (50 mA). The OPA454 device is a low-cost operational amplifier with high voltage (100 V) and relatively high current drive (50 mA). It is unity-gain stable and has a gain-bandwidth product of 2.5 MHz
The OPA454 is internally protected against overtemperature conditions and current overloads. It is fully specified to perform over a wide power-supply range of ±5 V to ±50 V or on a single supply of 10 V to 100 V. The status flag is an open-drain output that allows it to be easily referenced to standard low-voltage logic circuitry. This high-voltage operational amplifier provides excellent accuracy, wide output swing, and is free from phase inversion problems that are often found in similar amplifiers.
ENABLE and E/D Com
If left disconnected, E/D Com is pulled near V– (negative supply) by an internal 10-μA current source. When left floating, ENABLE is held approximately 2 V above E/D Com by an internal 1-μA source. Even though the active operation of the OPA454 results when the ENABLE and E/D Com pins are not connected, a moderately fast, negative-going signal capacitively coupled to the ENABLE pin can overpower the 1-μA pullup current and cause device shutdown. This behavior can appear as an oscillation and is encountered first near extreme cold temperatures. If the enable function is not used, a conservative approach is to connect ENABLE through a 30-Pf capacitor to a low-impedance source. Another alternative is the connection of an external current source from V+ (positive supply) sufficient to hold the enable level above the shutdown threshold.
Connections
- CN1: Pin 1 = Input Signal, Pin 2 = GND
- CN2: Pin 1 = Output, Pin 2 = GND
- CN3: Pin 1 = +50V DC, Pin 2 = GND, Pin 3 = -50V DC
- CN4: Pin 1 = SF This pin goes active for either an overcurrent or overtemperature condition, Pin 2 = GND
- J1: Enable/Disable, Connect to GND = Enable
- J2: No Use Pin 1 = EDCOM, Pin 2 = E/D, Pin 3 NC
Schematic
Parts List
NO. | QNTY. | REF. | DESC. | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 2 | CN1,CN4 | 2 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5315-ND |
2 | 1 | CN2 | 2 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1247-ND |
3 | 1 | CN3 | 3 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1248-ND |
4 | 5 | C1,C2,R3,R8,R9 | DNP | |||
5 | 4 | C3,C6,C7,C10 | 100nF/63V CERAMIC SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
6 | 4 | C4,C5,C8,C9 | 220uF/63V ELECTROLYTIC | NICHICON | DIGIKEY | 493-1942-ND |
7 | 1 | C11 | 100nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
8 | 2 | J1,J2 | 3 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5316-ND |
9 | 1 | Q1 | MJL21194 TO247 | ONSEMI | DIGIKEY | MJL21194GOS-ND |
10 | 1 | Q2 | MJL21193 TO247 | ONSEMI | DIGIKEY | MJL21193GOS-ND |
11 | 1 | R1 | 84.5K 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
12 | 1 | R2 | 10K 1% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
13 | 2 | R4,R10 | 0.2E 1% SMD SIZE 2512 | YAGEO/MURATA | DIGIKEY | |
14 | 1 | R5 | 0E SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
15 | 2 | R6,R7 | 10E 5% SMD SIZE 2512 | YAGEO/MURATA | DIGIKEY | |
16 | 1 | R11 | 100K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
17 | 1 | U1 | OPA454 SOIC8 | TI | DIGIKEY | 296-41370-1-ND |
18 | 1 | J1-SHUNT | SHUNT FOR JUMPER J1 | SULINS CONNECT | DIGIKEY | S9001-ND |
Block Diagram
Connections
