Instrumentation Amplifier For Pressure Sensor
- Rajkumar Sharma
- 18.923 Views
- moderate
- Tested
- SKU: EL70193
- Quote Now
General purpose differential amplifier project has been designed for various pressure sensor amplifier applications. Circuit provided with multiple resistors, capacitors, dual sensor options and 4 pin Header connector to interface other external sensors. Schematic is an example from NXP application AN1318 Figure 2.
The most popular silicon pressure sensors are piezo-resistive bridges that produce a differential output.
Voltage output is in response to pressure applied to a thin silicon diaphragm. Output voltage for these sensors is generally 25 to 50 mV full scales. Interface to microcomputers, therefore, generally involves gaining up the relatively small output voltage, performing a differential to single ended conversion, and scaling the analog signal into a range appropriate for analog to digital conversion. The circuit published here is simple solution which amplify low voltage differential signal and provide single output voltage which can be directly feed to ADC of micro-controller. Instrumentation amplifiers are by far the most common interface circuits that are used with pressure sensors. An example of an inexpensive instrumentation amplifier based interface circuit uses an LM358 dual operational amplifier and several resistors that are configured as a classic instrumentation amplifier with one important exception. PR2 Trimmer potentiometer provided to set the offset voltage 0.75V. Setting the offset voltage to 0.75 V results in a 0.75 V to 4.75 V output that is directly compatible with microprocessor A/D inputs. Over a zero to 50° C temperature range, combined accuracy for an MPX2000 series sensor and this interface is on the order of ± 10%. Trimmer potentiometer PR1 helps to set the gain. PCB provided with MPXM2010GS and MPXV2010DP dual footprint options, for testing purpose MPXV2010DP sensors has been used.
The MPXV2010 series silicon Piezo-Resistive pressure sensors provide a very accurate and linear voltage output directly proportional to the applied pressure. These sensors house a single monolithic silicon die with the strain gauge and thin film resistor network integrated. The sensor is laser trimmed for precise span, offset calibration and temperature compensation.
- Supply 10V DC Single Supply
- MPXV2010DP Pressure Range 0 to 10 kPa (0 to 1.45 psi)
- Output 0.75V to 4.75V Approx. (Adjustable)
- PR1 Trimmer Potentiometer Gain Adjust
- PR2 Trimmer Potentiometer Offset Adjust
Schematic
Hi! How do I buy this project?
We can produce this board for you, if order quantity is >10 pieces. If you are interested, please use the contact form to get in tough.
Hi Mike
Do you know if this board is proper for use with Motorola MPX-100AP Pressure Sensor?
Or what customization may be done?
Regards
Pescadito
Can we use this circuit for amplifing signal of MPX53dp for water level measurement purpose.
please reply.
i want to measure air flow can i measure flow with this circuit with tha help of arduino.
hello sir/madam it’s available in india if yes whats the price of this ckt. and whats its range in mmhg
