IR Remote Control Jammer
- 27.045 Views
- easy
- Non tested
Introduction
This circuit is a simple oscillator. Its frequency is in the range 35 kHz – 60 kHz and it’s adjustable.
Notes
- D1 is an infrared LED
- Values of components are shown in schematic
- All resistors are 0.25w and all capacitors are 16v
- With RV1 you can adjust the frequency
- For best results circuit work with 9v battery
- Pcb size is 2.5cm*3cm.
super project
is this functional and how it will work
Alguien sabe si el valor de R1 es 5.6ohms?
Es que no lo comprendo en ese punto
Luego el capacitor ceramico que indica C1 de 10/ que esta de pata 1 a pata 2, no se supone que tambien debe ser electrolitico,
Lo ultimo y mas importante este ocilador dice trabajar en frecuencias de kiloherzios y entre los 35 a 60khz
Mi pregunta es yo necesito uno para frecuencia de 60 pero HERTZIOS NO KILOHERZIOS gracias será que me sirva para inibidir o activar fototransistores trabajando a 60hz
English please.
What value (ohm) the R1?
R1 = 56 Ohm
What is the value of D1.
D1 is a simple Infrared Led, like those used on remote controls.
Sir this project is real or fake.
It is marked as non tested as you can see on the title, means we haven’t test it on our side.
RV1 means.
RV1 is a 1k potensiometer
