Infineon-IR2104-DS-vNA-EN.pdf - Electronics-Lab.com
24
DC Motor IR2104 H-BRIDGE
[Customadds id=643821] H-Bridge has been designed around IR2104 IC from International Rectifier. The board has been made mainly for DC-Motor applications. The driver can handle a load up to 8-10Amps. I have tested this board with 36V DC supply . The circuit also uses N Channel IR540 MOSFETS from ... Read More
