Isolated CAN Transceiver Module.pdf - Electronics-Lab.com
1
Isolated CAN BUS Transceiver Arduino Shield
[Customadds id=643821] The module described here is an isolated CAN Transceiver module. This module can be used as a standalone module or as an Arduino Uno shield. A controller area network is a two-wire high-speed serial network typically used to provide data communication between host and nodes... Read More
