Lead Acid Battery Voltage Monitor using ATMEGA328
[Customadds id=643821] Monitoring the voltage level of a 12V Lead Acid Battery (SLA) is easy and simple with this project. The board is made using an ATMEGA328 micro-controller and 12 x 5mm LEDs. The ATMEGA328 microcontroller senses the analog voltage on A3 Analog pin and drives 12 LEDs connected... Read More
- full (1500x709)
- medium (850x402)
- medium_large (640x303)
- large (640x303)
- 1536x1536 (1500x709)
- 2048x2048 (1500x709)
- re_large (783x600)
- menu-24x24 (24x11)
- menu-36x36 (36x17)
- menu-48x48 (48x23)
- woocommerce_single (600x284)
- wp_rp_thumbnail_prop (150x71)
