table.jpg - Electronics-Lab.com
24
Lead Acid Battery Voltage Monitor using ATMEGA328
[Customadds id=643821] Monitoring the voltage level of a 12V Lead Acid Battery (SLA) is easy and simple with this project. The board is made using an ATMEGA328 micro-controller and 12 x 5mm LEDs. The ATMEGA328 microcontroller senses the analog voltage on A3 Analog pin and drives 12 LEDs connected... Read More
