LED Lighting Effects Generator using PIC16F886
- Rajkumar Sharma
- 4.527 Views
- moderate
- Tested
- SKU: EL84140
- Quote Now
This project generates 8 different LED-lighting patterns (Visual Effects) and is based on PIC16F886. The project demonstrates different chasing effects being generated using 20 SMD LEDs and speed of LED-lighting moving is adjustable with the help of the on board trimmer potentiometer. 8 patters can be set using 3 on board PCB jumpers. Circuit consists of PIC16F886 micro-controller from Microchip and 20 SMD LEDs. Circuit works with 5V DC, Trimmer potentiometer provided to adjust speed of sequence.
- Supply 5V DC
- 8 Different Patters Possible ( LED-Lighting Sequence)
- Chasing speed adjustable
Schematic
Parts List
Connections
Jumper Settings
Very nice!
why didn’t you use switches ? Are those switches leads you any error ? I am gonna build the same circuit i’d glad if you help me 🙂
