Light and Dark Sensitive Switch
- Rajkumar Sharma
- 16.612 Views
- moderate
- Tested
- SKU: EL45866
- Quote Now
Light / Dark Sensitive Switch project is a simple project which operates a relay when the light falling on the LDR goes below or goes above a set point.
- Input – 12 V @ 50 mA
- Relay output – SPDT relay
- 2-in-1 kit, either as light sensitive kit or dark sensitive switch
- Onboard preset to set the level
- Power-On LED indicator
- Relay On LED indicator
- Power Battery Terminal (PBT) for easy relay output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 50 mm x 54 mm
Schematic
Please give me a details of pcb where shall i get
Check on this website http://kealab.com for kit purchase
