Liquid or Air Pressure Switch with Relay
[Customadds id=643821] This pressure switch project is built using a piezoresistive transducer, LM358 OPAMP as comparator, and a relay. The circuit activate the relay when the pressure in a system exceed a given set-point. Basically, this switch can power ON or OFF a pump, valve, motor, when cert... Read More
- full (1101x761)
- medium (850x588)
- medium_large (640x443)
- large (640x443)
- 1536x1536 (1101x761)
- 2048x2048 (1101x761)
- re_large (783x600)
- menu-24x24 (24x17)
- menu-36x36 (36x25)
- menu-48x48 (48x33)
- woocommerce_single (600x415)
- wp_rp_thumbnail_prop (150x104)
