mpxv5010dp-differential-pressure-sensor-5v-analog-output.jpg - Electronics-Lab.com
Liquid or Air Pressure Switch with Relay
[Customadds id=643821] This pressure switch project is built using a piezoresistive transducer, LM358 OPAMP as comparator, and a relay. The circuit activate the relay when the pressure in a system exceed a given set-point. Basically, this switch can power ON or OFF a pump, valve, motor, when cert... Read More
- full (656x514)
- medium (300x235)
- medium_large (640x640)
- large (640x501)
- 1536x1536 (656x514)
- 2048x2048 (656x514)
- re_large (783x600)
- menu-24x24 (24x19)
- menu-36x36 (36x28)
- menu-48x48 (48x38)
- sendpress-max (600x470)
- woocommerce_single (600x470)
- wp_rp_thumbnail_prop (150x118)
