Liquid or Air Pressure Switch with Relay
[Customadds id=643821] This pressure switch project is built using a piezoresistive transducer, LM358 OPAMP as comparator, and a relay. The circuit activate the relay when the pressure in a system exceed a given set-point. Basically, this switch can power ON or OFF a pump, valve, motor, when cert... Read More
- full (806x332)
- medium (300x124)
- medium_large (640x263)
- large (640x264)
- 1536x1536 (806x332)
- 2048x2048 (806x332)
- re_large (783x332)
- menu-24x24 (24x10)
- menu-36x36 (36x15)
- menu-48x48 (48x20)
- sendpress-max (600x247)
- woocommerce_single (600x247)
- wp_rp_thumbnail_prop (150x62)
