LMD18200 H-Bridge Module for DC Motor
- Rajkumar Sharma
- 14.141 Views
- moderate
- Tested
- SKU: EL47450
- Quote Now
The module has been designed around LMD18200 from Texas Instruments. The LMD18200 is a 3A H-Bridge designed for motion control applications. The device is built using a multi-technology process which combines bipolar and CMOS control circuitry with DMOS power devices on the same monolithic structure. Ideal for driving DC and stepper motors; the LMD18200 accommodates peak output currents up to 6A. An innovative circuit which facilitates low-loss sensing of the output current has been implemented.
- Powerful bi-directional DC Motor driver
- Screw-terminals for Power Supply and Motor Connections
- 6-pin Header connector for PWM, direction, current sense, Brake
- Delivers Up to 3A Continuous Output (6A Peak)
- Operates at Supply Voltages Up to 55V
- Low RDS (ON) Typically 0.33Ω per Switch at 3A
- TTL and CMOS Compatible Inputs
- No “Shoot-Through” Current
- Thermal Warning Flag Output at 145°C
- Thermal Shutdown (Outputs Off) at 170°C
- Internal Clamp Diodes
- Shorted Load Protection
- Internal Charge Pump with External Bootstrap Capability
- Mounting holes of 2.6 mm each
- PCB dimensions 44 mm x 25 mm
Schematic
Parts List
Connections
Photos
Login
