bom.png - Electronics-Lab.com
92
Low noise Mini Electret Microphone PreAmplifier
[Customadds id=643821] This single supply microphone pre-amplifier amplifies the output signal of an electret capsule microphone to audio line levels. An op-amp is used as a trans-impedance amplifier to convert the output current from the microphone into a signal-level voltage. The circuit works ... Read More
