Magnet Based Rotary/Linear Encoder Module with Quadrature Output
[Customadds id=643821] This sensor module is a simple solution to build a magnet-based rotary encoder. The project is based on the AS5304 chip with integrated Hall elements for measuring linear or rotary motion using multi-pole magnetic strips or rings. This allows the usage of the module in appl... Read More
- full (1500x889)
- medium (850x504)
- medium_large (640x379)
- large (640x379)
- 1536x1536 (1500x889)
- 2048x2048 (1500x889)
- re_large (783x600)
- menu-24x24 (24x14)
- menu-36x36 (36x21)
- menu-48x48 (48x28)
- sendpress-max (600x356)
- woocommerce_single (600x356)
- wp_rp_thumbnail_prop (150x89)
