application schematic.jpg - Electronics-Lab.com
34
Magnet Based Rotary/Linear Encoder Module with Quadrature Output
[Customadds id=643821] This sensor module is a simple solution to build a magnet-based rotary encoder. The project is based on the AS5304 chip with integrated Hall elements for measuring linear or rotary motion using multi-pole magnetic strips or rings. This allows the usage of the module in appl... Read More
