Magnet Based Rotary/Linear Encoder Module with Quadrature Output
[Customadds id=643821] This sensor module is a simple solution to build a magnet-based rotary encoder. The project is based on the AS5304 chip with integrated Hall elements for measuring linear or rotary motion using multi-pole magnetic strips or rings. This allows the usage of the module in appl... Read More
- full (641x727)
- medium (641x727)
- medium_large (640x726)
- large (640x726)
- 1536x1536 (641x727)
- 2048x2048 (641x727)
- re_large (641x600)
- menu-24x24 (21x24)
- menu-36x36 (32x36)
- menu-48x48 (42x48)
- woocommerce_single (600x680)
- wp_rp_thumbnail_prop (150x170)
