PCB_Bottom.pdf - Electronics-Lab.com
1
Motorcycle Universal Gear Indicator
Introduction This is a new design for a universal gear indicator that can be fitted to any motorcycle as an aftermarket accessory. Its main advantage is that its operation depends entirely on the gear shift lever movement, instead of connecting to speedometer and tachometer sensors (found in expe... Read More
