NiCad-NiMh Battery Monitor
- Rajkumar Sharma
- 10.303 Views
- moderate
- Tested
- SKU: EL36508
- Quote Now
This project is a NiCad-NiMh Battery Monitor based on LM3914 IC
Description
The simple project can be used as test gear. Its easy way to monitor the battery voltages, especially dry cell, NICAD, NIMH, supply up to 1.5 Voltage. Battery Monitor range 0.15V to 1.5V. The project is built around Texas instruments LM3914, The LM3914 senses the voltage levels of the battery and drives the 10 light emitting diodes based on the voltage detected on input connector. Circuit works on 5V DC. J1 Jumper is used to select the DOT mode or bar graph mode.
Schematic
Parts
Login
