One Channel Relay Driver
- Rajkumar Sharma
- 11.652 Views
- easy
- Tested
- SKU: EL37005
- Quote Now
This project is an one Channel Relay Driver suitable for a variety of projects.
Description
Single Channel Relay project is a simple and convenient way to interface a relay for switching application in your project.
Specifications:
- Input – 12 VDC @ 42 mA
- Output – SPDT relay
- Relay specification – 5 A @ 230 VAC
- Trigger level – 2 ~ 15 VDC
- Header pins for connecting power and trigger voltage
- LED indicates relay status
- Power Battery Terminal (PBT) for easy relay output connection
- Four mounting holes of 3.2 mm each
- PCB dimensions 27 mm x 69 mm
Schematic
real world projects
