PIC16F 28/40 Pin Development Board
- Rajkumar Sharma
- 16.534 Views
- moderate
- Tested
- SKU: EL62181
- Quote Now
PIC16F 28/40-pin Development Board will help you with your prototyping requirement with any of Microchip’s 28/40-pin of 16F PIC microcontrollers.
Specifications
- All ports terminating in separate box header connector with 5 VDC source option
- ICSP connector for programming for the PIC’s with ICD support
- Jumper selectable onboard pull-up resistors for Port A.4 pin on the microcontroller
- Bridge in the input provides any polarity DC supply connection to the board
- 20 MHz crystal source
- Onboard +5V voltage regulator
- Four mounting holes of 3.2 mm each
- PCB dimensions 77 mm x 82 mm
Schematic
Parts List
Photos
Login
