Portable Audio Amplifiers
- Izhar Fareed
- http://www.extremecircuits.net
- izhar@gmx.us
- 27.857 Views
- easy
- Non tested
Description
Above circuits are based on TEA2025 is a monolithic integrated audio amplifier in a 16-pin plastic dual in line package manufactured by UTC .Circuit has an Internal Thermal Protector. It is designed for portable cassette players and radios. You can also use it as your PC Audio Amplifier. A few external components required to build this circuit. Use 9v transformer to play the circuit. But not more than DC12v. Because it can damage the amplifier IC. So build n Enjoy.
Stereo per channel
VCC=9V;RL=4Ω/3W
VCC=9V;RL=8Ω/2W
Bridge Application
VCC=9V;RL=8Ω/5W
VCC=9V;RL=4Ω/8W
Specifications
Supply Voltage min = DC3v @ 500mA
Supply Voltage max = DC12v @ 500mA
Supply Voltage recommended = DC9v @500mA
Is there a substitution for tea2025
It seems that TEA2025 is obsolete, but you can still find it online and on ebay. It seems there is not substitution available.
