Proximity Distance Sensor.pdf - Electronics-Lab.com
3
Proximity Distance Sensor using DRV5053 Hall effect Sensor
[Customadds id=643821] This is a hall sensor proximity sensor that can detect magnetic targets approaching the sensor, without physical contact with the target. This sensor also can be used to detect the distance range 0-4cm (0-40mm). The target distance can be adjusted using the onboard trimmer ... Read More
