Proximity Distance Sensor using DRV5053 Hall effect Sensor
[Customadds id=643821] This is a hall sensor proximity sensor that can detect magnetic targets approaching the sensor, without physical contact with the target. This sensor also can be used to detect the distance range 0-4cm (0-40mm). The target distance can be adjusted using the onboard trimmer ... Read More
- full (1383x599)
- medium (850x368)
- medium_large (640x278)
- large (640x278)
- 1536x1536 (1383x599)
- 2048x2048 (1383x599)
- re_large (783x599)
- menu-24x24 (24x10)
- menu-36x36 (36x16)
- menu-48x48 (48x21)
- sendpress-max (600x260)
- woocommerce_single (600x260)
- wp_rp_thumbnail_prop (150x65)
