RMS Noise to DC Converter – RMS Noise Measurement
- Rajkumar Sharma
- 43 Views
- easy
- Tested
- SKU: EL148470
- Quote Now
This mini-module helps users to measure the RMS noise of AC signal. Apply the AC noise signal to the input and the circuit outputs a DC voltage. Signal bandwidth is 1Khz to 100Khz and input sensitivity is 1 μVolt RMS. The LT6203 ultra-low noise, low power op-amp amplifies the low-level signal. Further, this signal is converted into a DC voltage by LTC1966 True RMS converter chip from Analog Devices. The circuit works with dual supply +/-5V DC and consumes very low current.
VOutput = 1mVDC/1μVolt RMS Noise
Credits: Schematic is from Analog Devices Application note.
- Supply Dual 5V DC (+/-5V DC)
- Input Sensitivity 1 Microvolt RMS Type
- Screw Terminal Connector for Input Signal
- Header Connector for Output and Power Input
- On Board Power LED
- PCB Dimensions 36.51 x 14.61mm
Schematic
Parts List
NO. | QNTY. | REF. | DESC. | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 2 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1247-ND |
2 | 1 | CN2 | DNP | |||
3 | 1 | CN3 | 5 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5318-ND |
4 | 5 | C1,C6,C7,C8,C10 | 100nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
5 | 1 | C2 | DNP | |||
6 | 1 | C3 | 1uF/16V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
7 | 2 | C4,C9 | 10uF/16V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
8 | 1 | C5 | 1.5uF/16V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
9 | 1 | D1 | LED RED SMD SIZE 0805 | OSRAM | DIGIKEY | 475-1278-1-ND |
10 | 2 | L1,L2 | FERRITE BEAD 600OHM/100MHZ SMD SIZE 0805 | LAIRD | DIGIKEY | 240-2390-1-ND |
11 | 1 | R1 | 10K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
12 | 2 | R2,R5 | 100E 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
13 | 1 | R3 | 0E SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
14 | 1 | R4 | 100K 1% smd size 0805 | YAGEO/MURATA | DIGIKEY | |
15 | 1 | R6 | 1K 1% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
16 | 1 | U1 | LTC6203 MSOP8 | ANALOG DEVICE | DIGIKEY | LT6203CS8#PBF-ND |
17 | 1 | U2 | LTC1966 MSOP8 | ANALOG DEVICE | DIGIKEY | 505-LTC1966CMS8#PBF-ND |
Connections
Gerber View
Photos
Video
LTC1966 Datasheet
Login
