RS232_Module_TOP.jpg - Electronics-Lab.com
2
RS232 - MAX232 Interface Module
[Customadds id=643821] This project is a RS232 Interface Board based on MAX232 IC. Description This project  provides you a simple and easy solution to connect / convert your Microcontroller input/output to be connected to the serial port of the Computer. This projects build around  popu... Read More
