RS232 or RS485 Module
- Rajkumar Sharma
- 9.978 Views
- moderate
- Tested
- SKU: EL39229
- Quote Now
This project is a RS232 & RS485 Interface Board
RS232 or RS485 Board will help you provide a seamless connection of either of the protocol RS232 or RS485 with your interfacing circuit.
Specifications
- 5 VDC Supply sourced through the Box Header interfacing connector
- Either of the two communication protocol available by use of individual IC on the PCB
- PBT type connector for connection of the RS485 link cable and 9 pin female type D connector for interfacing of UART signals to the PC
- Four mounting holes of 3.2 mm each
- PCB dimensions 38 mm x 61 mm
Schematic
Parts List
This project is simple, but it was VERY helpful to me to understand how to connect the MAX485 for a project that I am working on.
