RS232 to RS485 Module
- Rajkumar Sharma
- 20.670 Views
- medium
- Tested
- SKU: EL44341
- Quote Now
RS232 to RS485 Board (R) provides a seamless connection of the PC to an RS485 network.
- Simplex connection of this interface to the RS485 network
- Easy way of switching the modes between Receiver and Transmitter ( Slide Switch)
- 5 V regulated supply provision on board
- 9-pin, PCB mounted, Female type D-connector available
- Supply can also be provided by the host interface via Header connector carrying data
- Four mounting holes 3.2 mm each
- PCB dimensions 82 mm x 33 mm
Schematic
Parts List
Photos
Login
