Sinewave generator
- Rajkumar Sharma
- 16.640 Views
- moderate
- Tested
- SKU: EL44930
- Quote Now
Sine wave Generator project will provide you with a Sinusoidal Waveform output to test various instruments. You can also use the High quality output from this kit to insert a tone modulation in your audio and RF equipment. This kit is designed using XR2206 IC to provide High Stability and Accuracy.
- Supply input 12 VDC Max @ 50 mA
- Range: Jumper selectable and preset tunable range of 10 Hz – 100 KHz
- Output Level can be controller with onboard preset
- Power-On LED indicator
- Screw terminal connector for easy connection
- PCB dimensions 55 mm x 50 mm
Schematic
Parts List
Login
