pcb_top.jpg - Electronics-Lab.com
4
Solenoid, Relay, Valve Driver with Current Regulation
[Customadds id=643821] The project presented here is a PWM current driver for solenoids, Relays, and valves. The board will regulate the current with a well-controlled waveform to activate and reduce power dissipation at the same time. The solenoid current is ramped up fast to ensure the opening ... Read More
