Step Up DC-DC Converter - 24V/10mA Output from 12V DC Input - Compatible to TO220 LDO
[Customadds id=643821] The project demonstrated here is a small-size solution, high-efficiency, low-cost, and low-EMI step-up DC/DC module for LDO regulator replacement. This small size module helps save on solution size and cost while also eliminating the need for a heatsink. The module takes up... Read More
- full (1500x727)
- medium (850x412)
- medium_large (640x310)
- large (640x310)
- 1536x1536 (1500x727)
- 2048x2048 (1500x727)
- re_large (783x600)
- menu-24x24 (24x12)
- menu-36x36 (36x17)
- menu-48x48 (48x23)
- sendpress-max (600x291)
- woocommerce_single (600x291)
- wp_rp_thumbnail_prop (150x73)
