Stereo Balanced to Unbalanced Audio Converter.pdf - Electronics-Lab.com
2
[Customadds id=643821] The primary role of this project is to convert a differential input audio signal into a single-ended output signal while rejecting noise that is common to both inputs (common-mode noise). The circuit presented here is a differential amplifier intended to receive balanced... Read More
