Stereo tape head preamplifier using LA3161
- Rajkumar Sharma
- 24.965 Views
- moderate
- Tested
- SKU: EL34058
- Quote Now
The Stereo Tape Head Preamplifier kit is based on LA3161 IC from SANYO.
Specifications
- Power supply – 9 ~ 12 VDC @ 20 mA
- Output power – upto 200 mW
- Input Resistance – 100 KΩ (Typ), Load Resistance – 10 KΩ (Typ)
- Low noise, good ripple rejection owing to the on-chip voltage regulator
- Berg pins for connecting power supply, input and output
- Power-On LED indicator
- Four mounting holes of 3.2 mm each
- PCB dimensions 51 mm x 54 mm
Schematic
Parts List
