[Customadds id=643821] Description This is a novel flasher circuit using a single driver transistor that takes its flash-rate from a flashing LED. The flasher in the photo is 3mm. An ordinary LED will not work. The flash rate cannot be altered by the brightness of the high-bright white LED c... Read More
- full (225x214)
- medium (225x214)
- medium_large (225x214)
- large (225x214)
- 1536x1536 (225x214)
- 2048x2048 (225x214)
- re_large (225x214)
- re_xxmedium (225x214)
- re_xmedium (225x214)
- re_medium (225x214)
- crp_thumbnail (225x214)
- menu-24x24 (24x24)
- menu-36x36 (36x34)
- menu-48x48 (48x46)
- woocommerce_thumbnail (225x214)
- woocommerce_single (225x214)
- wp_rp_thumbnail_prop (150x143)
