Two Channel High Side Driver with Analog Sense for Automotive Applications
- Rajkumar Sharma
- 157 Views
- easy
- Tested
- SKU: EL138982
- Quote Now
The project presented here is suitable for all types of resistive, inductive, and capacitive loads, and can also be used to drive LEDs. The board is built using 2 x VN5025AJ chips which are monolithic devices made using STMicroelectronics VIPower technology. It is intended for driving resistive or inductive loads with one side connected to the ground. Active VCC pin voltage clamp protects the device against low energy spikes. This device integrates an analog current sense which delivers a current proportional to the load current (according to a known ratio) when CS_DIS is driven low or left open. When CS_DIS is driven high, the CURRENT SENSE pin is in a high impedance condition. Output current limitation protects the device in overload conditions. In case of long overload duration, the device limits the dissipated power to a safe level up to thermal shut-down intervention. Thermal shut-down with automatic restart allows the device to recover normal operation as soon as the fault condition disappears.
- Power Supply 4.5V to 30V (Up to 36V Limited by Capacitor Voltage)
- Load Current Up to 10 Amps Per Channel (Peak Current 41A)
- Current Sense Voltage Output 0.5V/Amp
- Under Voltage Threshold 3.5V
- Turn On Delay 30 micro-Seconds (4.3Ohms Load)
- Turn OFF Delay 50 micro-Seconds (4.3Ohms Load)
- Temperature Shutdown Threshold 175 Degree Centigrade
- Inrush current active management by power limitation
- Very low standby current
- 0V CMOS-compatible input
- Optimized electromagnetic emission
- Very low electromagnetic susceptibility
- In compliance with the 2002/95/EC European directive
- PCB Dimensions 41.91 x 38.58 mm
- 4 x 3 mm mounting holes
Diagnostic functions
- Proportional load current sense
- High current sense precision for wide range currents
- Current sense disables
- Thermal shutdown indication
- Very low current sense leakage
Protection
- Undervoltage shut-down
- Overvoltage clamp
- Load current limitation
- Self-limiting of fast thermal transients
- Protection against loss of ground and loss of Vcc
- Thermal shut down
Schematic
Parts List
NO | QNTY | REF | DESC | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 3 | CN1,CN2,CN4 | 2 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1247-ND |
2 | 2 | CN3,CN5 | 5 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5318-ND |
3 | 2 | C1,C5 | 100nF/50V CERAMIC SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
4 | 1 | C2 | 100uF/35V SMD Electrolytic | NICHICON | DIGIKEY | 493-2203-1-ND |
5 | 2 | C3,C4 | 10nF/50V CERAMIC SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
6 | 1 | D1 | LED RED SMD SIZE 0805 | LITE ON INC | DIGIKEY | 160-1427-1-ND |
7 | 1 | R1 | 4.7K 5% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
8 | 6 | R2,R3,R4,R6,R7,R8 | 10K 5% SMD SIZE 0805 | YAGEO/MURATA | DIGIKEY | |
9 | 2 | R5,R9 | 1.5K 5% SMD SIZE 1206 | YAGEO/MURATA | DIGIKEY | |
10 | 2 | U1,U2 | VN5025AJTR-E | ST | DIGIKEY | 497-11469-1-ND |
Connections
Current Sense Delay
Truth Table
Chip Block Diagram
