USB to UART Converter with GPIO – MCP220
- Rajkumar Sharma
- 11.787 Views
- easy
- Tested
- SKU: EL48776
- Quote Now
The Module is based on The MCP2200, which is a USB-to-UART serial converter which enables USB connectivity in application that have a UART interface. The device reduces external components by integrating the USB termination resistors. The MCP2200 also has 256-bytes of integrated user EEPROM. The MCP2200 has eight general purpose input / output pins. Four of the pins have alternate functions to indicate USB and communication status.
Specifications
- Supply 3- 5V DC
- On Board TX & RX LED
- USB activity LED outputs (TxLED and RxLED)
- Mini USB Interface
- 6 + 6 PIN Header Connector for I/O and RX-TX Signals
- UART signal polarity option General Purpose Input/output (GPIO) Pins
- Eight (8) general purpose I/O pins
- Supports Full-Speed USB (12 Mb/s)
- Implements USB Protocol Composite Device CDC Device (communications and control)
- Class 02h – CDC: USB-to-UART communications and I/O control
- Class 03h – HID: I/O control, EEPROM access, and initial configuration
- 128 byte buffer to handle data throughput at any UART baud rate
- 64 byte transmit
- 64 byte receive
- Fully configurable VID and PID assignments and string descriptors
- Bus Powered or self-powered USB Driver and Software Support
- Royalty-free drivers for Virtual Com Port (VCP)
- Windows XP (SP2 and later)/Vista/7
- Configuration utility for initial configuration
- Universal Asynchronous Receiver/Transmitter (UART)
- Support baud rates: 300 – 1000k (baud)
- Hardware flow control
- 256 bytes of user EEPROM
- SSPND output pin
- ULOAD output pin (indicates if requested current was allowed).
- Oscillator input: 12 MHz
Schematic
Parts List
Login
