Warning LED Flash Light
- Rajkumar Sharma
- 12.924 Views
- easy
- Tested
- SKU: EL45990
- Quote Now
LED Flasher is a simple project producing a flashing effect of six LED’s. This project can be used in all areas where you want to draw attention. Hi-glow LED’s providing enough flashing light to attract your attention. Can be used as warning light.
Specifications
- Supply input 12 V @ 35 mA (6 to 15V Dc Possible)
- Onboard preset to adjust flash rate
- Terminal pins for connecting supply input
- Four mounting holes of 3.2 mm each
- PCB dimensions 53 mm x 35 mm
- CN1: Supply in 12V DC (6V-15V Supply Possible)
- PR1 : Flash Frequency Adjust
Schematic
Parts List
Video
Login
