Xenon Flash Tube Driver
- Rajkumar Sharma
- 123 Views
- medium
- Tested
- SKU: EL143599
- Quote Now
This is a Xenon Flash tube driver board and consists of a high voltage AC to DC converter circuit, a DC storage capacitor, a trigger circuit that will fire the xenon lamp, an Optocoupler to control the flashes etc. The circuit requires 220VAC and trigger pulse which should be between 3V to 5V. The input trigger pulse is optically isolated and can be interfaced with Arduino or other circuits. The circuit works well with a 2Hz to 10Hz trigger frequency.
Note: The board operates at lethal voltages and has bulk capacitors that store significant charge, even when disconnected from the power source. Accidental contact can lead to lab equipment damage, personnel injury, or may be fatal. Please be exceptionally careful when probing and handling this board. Always observe normal laboratory precautions.
The project can be tested with simple Arduino code which is available as download. Connect the D4 pin to trigger input and enjoy the magic of the flash tube.
- Supply 220V AC
- Flash Frequency 2-10Hz
- Trigger Input 3V to 5V DC
- Trigger Input Optically Isolated
- 4 x 4 mm PCB Mounting Holes
- PCB Dimensions 73.66 x 43.18 mm
Connections
- CN1: Pin 1 220V AC Live, Pin 2 GND
- CN2: Pin 1 5V Trigger Input, Pin 2 GND (Flash Trigger Input 3V to 5V)
- CN3: Pin 1 Flash Tube Anode, Pin 2 Flash Tube Trigger, Pin 3 Flash Tube Cathode
Schematic
Parts List
NO. | QNTY. | REF. | DESC | MANUFACTURER | SUPPLIER | SUPPLIER PART NO |
1 | 1 | CN1 | 2 PIN SCREW TERMINAL PITCH 5.08MM | PHOENIX | DIGIKEY | 277-1247-ND |
2 | 1 | CN2 | 2 PIN MALE HEADER PITCH 2.54MM | WURTH | DIGIKEY | 732-5315-ND |
3 | 1 | C1 | 22uF/450V ELECTROLYTIC | RUBYCON | DIGIKEY | 1189-2936-ND |
4 | 1 | C2 | 0.1uF/275VX2AC | KEMET | DIGIKEY | 399-9651-ND |
5 | 4 | D1,D2,D3,D4 | 1N4007 DIODE THT | DIOTEC SEMI | DIGIKEY | 4878-1N4007TR-ND |
6 | 1 | LP1 | SCREW TERMINAL PITCH 7.62MM | PHOENIX | DIGIKEY | 277-5954-ND |
7 | 1 | Q1 | BT136 TO220 | NXP | DIGIKEY | 2156-BT136X-600F,127-ND |
8 | 1 | R1 | 1K 5%, 10W RESISTOR THT | VITROHM | DIGIKEY | 3964-KHS10AJB-AX-1KAA-ND |
9 | 2 | R2,R5 | 100K 5% 1/4W THT | YAGEO | DIGIKEY | |
10 | 1 | R3 | 180E 5% 1/4W THT | YAGEO | DIGIKEY | |
11 | 1 | R4 | 470E 5% 1/4W THT | YAGEO | DIGIKEY | |
12 | 1 | R6 | DNP | |||
13 | 1 | TR1 | TRIGGER COIL-FOR XENON TUBE | EXCELITAS TECHNOLOGY | DIGIKEY | ZS1324-24VLUL1(H)-ND |
14 | 1 | U1 | MOC3021 | ONSEMI | DIGIKEY | MOC3021MFS-ND |
15 | 1 | SOCKET | 6 PIN DIP SOCKET | ASSAMANN | DIGIKEY | 123-AR06-HZL-TT-ND |
16 | 1 | XENON TUBE U SHAPE | MOFLASH | RS COMP | 660-1117 |
Connections
Gerber View
Photos
Video
BT136 Datasheet
Login
