Tag: 3.3V
![3.3V-5A Output DC-DC Converter with 10 to 24V Input 3.3V-5A Output DC-DC Converter with 10 to 24V Input](https://www.electronics-lab.com/wp-content/uploads/2023/04/002-1-1024x614.jpg)
The project published here is a synchronous step-down DC/DC converter based on the RT7258 chip. The chip has integrated high-side internal power MOSFET and gate driver for a low-side external power MOSFET. The board delivers 3.3V DC - 5A output current from 10V to 24V input supply....
Continue Reading![Multiple Output Power Source – Dual 10V (+/-10V), 5V DC, 3.3V DC from 9V Battery Multiple Output Power Source – Dual 10V (+/-10V), 5V DC, 3.3V DC from 9V Battery](https://www.electronics-lab.com/wp-content/uploads/2022/01/008-1-1024x812.jpg)
This is a multiple output power converter module that provides +/-10V (Dual 10V), 5V DC, and 3.3V DC from a 9V PP3 battery. This is a very useful project that has been designed for low-load current applications. Dual +/-10V output from a 9V battery is a key feature of the project. The...
Continue Reading![+/-18V Isolated DC-DC Converter Dual Supply Output from USB 5V Power Input +/-18V Isolated DC-DC Converter Dual Supply Output from USB 5V Power Input](https://www.electronics-lab.com/wp-content/uploads/2021/01/1-10-1024x626.jpg)
This is a mini DC-DC converter with dual output from single 5V DC supply or USB power source (e.g., +/-18V from 5V/USB). The mini board will fit into small space and perform with high efficiency. Basically, the circuit transfers power from 5V/USB to the output side +/-18V with high...
