Tag: 3-phase
![Smart Power Module for 3-Phase Motor – 5A Smart Power Module for 3-Phase Motor – 5A](https://www.electronics-lab.com/wp-content/uploads/2024/05/001-11-1024x751.jpg)
This is a Smart power module project designed for Small Power AC Motors. The FNB40560 chip is the heart of the project. A compact inverter project is ideal for small power motors such as fans and pumps. H-bridge configuration can also be created for low current high-voltage brushed DC...
Continue Reading![3-Phase Advance Motion Module – 400VDC – 4A 3-Phase Advance Motion Module – 400VDC – 4A](https://www.electronics-lab.com/wp-content/uploads/2024/05/002-7-1024x819.jpg)
This is an advanced Motion module providing a fully featured, high-performance inverter output stage for AC induction, BLDC and PMSM motors such as refrigerators, fans, and pumps. This module is based on NFA50460 chip which integrates the optimized gate drive of the built−in IGBTs...
Continue Reading![High Voltage 3-Phase Full-Wave PWM Brushless Motor Driver High Voltage 3-Phase Full-Wave PWM Brushless Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2024/05/012-3-1024x862.jpg)
The project presented here is a three-phase sinewave PWM driver for high-voltage brushless motors. The board is built using TB67B000AHG chip, which is a high-voltage IC capable of handling 600V. The TB67B000AHG has a 2-in-1 (MCP) structure of controller (sine-wave PWM / wide-angle...
Continue Reading![3 Phase IPM Module for Small Power AC Motor 3 Phase IPM Module for Small Power AC Motor](https://www.electronics-lab.com/wp-content/uploads/2024/05/002-2-1024x917.jpg)
This is a 3-Phase Inverter Driver project designed for Small Power AC Motors. The project is built using FSB50550AT IPM chip. This compact and reliable inverter project is ideal for small power motors such as fans and pumps. An H-bridge configuration can also be created for low...
Continue Reading![Signal Conditioner for Sensorless BLDC Operations Signal Conditioner for Sensorless BLDC Operations](https://www.electronics-lab.com/wp-content/uploads/2021/10/004-6-1024x679.jpg)
This is a back EMF signal conditioning circuit that can be used to develop high-voltage sensorless motor drivers. When a sensorless algorithm is used to control the BLDC motor speed, the Back EMF (BEMF) signals are used. Based on zero crossing of BEMF signals, motor commutation is...
Continue Reading![3 Phase AC input – DC Output – High Voltage DC Power Supply (2KW) 3 Phase AC input – DC Output – High Voltage DC Power Supply (2KW)](https://www.electronics-lab.com/wp-content/uploads/2021/07/014-1-1024x772.jpg)
Although this power supply design is specific to the Intelligent Power Modules (IPM) VFD drives, high voltage boost converters, high voltage battery chargers, etc, the concept and circuit design may be used for any power supply that requires a high voltage output of up to 800V DC and...
Continue Reading![Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2021/04/003-1-1024x692.jpg)
Driving a 3-phase brushless DC motor is very easy with this project. It is a simple and easy-to-build project that requires only a few external components. The circuit is based on AMT49400 IC which is an advanced 3-phase, Sensorless, brushless DC (BLDC) motor driver with integrated...
