Tag: current sense
![4 Channel Current Sense Amplifier – Low and High-Side Voltage Output 4 Channel Current Sense Amplifier – Low and High-Side Voltage Output](https://www.electronics-lab.com/wp-content/uploads/2023/08/003-9-1024x970.jpg)
This 4-Channel current sense amplifier is designed for cost-optimized applications. This is a current-sense amplifier (also called a current-shunt monitor) that senses the voltage drop across current-sense resistors at common-mode voltages from –0.2 V to +26 V, independent of the...
Continue Reading![Current-Sense Amplifier with Dual Over Current Level Monitor & Alert Output Current-Sense Amplifier with Dual Over Current Level Monitor & Alert Output](https://www.electronics-lab.com/wp-content/uploads/2022/04/001-3-1024x538.jpg)
The project presented here is a high common-mode current sense amplifier with two high-speed comparators to detect out-of-range current conditions. The comparators are configured to detect and respond to dual over current conditions. These devices feature an adjustable limit threshold...
