Tag: DC motor
![Bluetooth Robot Car Controller using ESP32 Bluetooth Robot Car Controller using ESP32](https://www.electronics-lab.com/wp-content/uploads/2024/01/001-10-1024x842.jpg)
This wireless robot car controller board is built using an ESP32 BT/Wi-Fi module, 2 x H-Bridges, 3.3V regulator. It also includes an ESP32 programming connector, power LED, screw terminal connector for the power supply, header connector for motors, and high-value capacitors on the DC...
Continue Reading![Position and Speed Controller for DC Motor with Incremental Encoder Position and Speed Controller for DC Motor with Incremental Encoder](https://www.electronics-lab.com/wp-content/uploads/2024/01/005-7-1024x915.jpg)
This project consists of Arduino Arduino-compatible microcontroller ATmega328, an L298 Motor driver, a Joystick, a programming connector, an Infrared sensor, and various analog and digital I/O pins. The project is Arduino compatible and can be programmed using Arduino IDE and many...
Continue Reading![DC Motor Control Using Joystick DC Motor Control Using Joystick](https://www.electronics-lab.com/wp-content/uploads/2023/10/001-1-1024x717.jpg)
This is a compact, low-profile, and high-performance DC motor driver that provides easy control of a DC motor using a joystick. This small-size board can drive small to medium-sized brushed DC motors with up to 2.5A continuous and 6A peak currents. It is an Arduino-compatible project...
Continue Reading![Brushed DC Motor Speed Controller Using Radio Control (RC) Remote Brushed DC Motor Speed Controller Using Radio Control (RC) Remote](https://www.electronics-lab.com/wp-content/uploads/2023/05/003-9-1024x896.jpg)
This is a Brushed DC motor controller designed to control one brushed DC motor up to 5A. It can control the speed of the DC motor using a Radio Control (RC) System. This Arduino compatible hardware converts RC PWM signal into 0 to 100% duty cycle PWM which further drives high current...
Continue Reading![High Power DC Motor Speed and Direction Control using RC Transmitter – Arduino Compatible High Power DC Motor Speed and Direction Control using RC Transmitter – Arduino Compatible](https://www.electronics-lab.com/wp-content/uploads/2023/05/005-5-1024x750.jpg)
The project presented here is a low-cost solution to control the speed and direction of a high-power brushed DC motor using RC (Radio Remote Control) transmitter. This is an Arduino-compatible board, consisting of an Atmega328 chip, 2 x Relay for motor direction control, MOSFET for...
Continue Reading![High Performance – High Reliability 50V DC Brush Motor Driver High Performance – High Reliability 50V DC Brush Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2022/07/002-3-1024x771.jpg)
This is a powerful yet small size low profile brushed DC motor drive system with a few key features like adjustable constant current control, direction control, brake controls, Alert output, PWM for speed control etc. BD63130AFM chip is the heart of the project which is an H-bridge...
Continue Reading![15V to 60V – Three-Phase Brushless DC Motor Pre-Driver 15V to 60V – Three-Phase Brushless DC Motor Pre-Driver](https://www.electronics-lab.com/wp-content/uploads/2021/04/C-1024x543.jpg)
The project presented here is a three-phase BLDC motor pre-driver. The project consists of 3x half-bridge IR2101 driver IC and 6 channel high current N-MOSFETS. The project can be configured as 3 independent half-bridges H-bridge for a brushed DC motor, or a single high current...
Continue Reading![Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver Sensorless FOC 3 Phase Low Power Brushless BLDC Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2021/04/003-1-1024x692.jpg)
Driving a 3-phase brushless DC motor is very easy with this project. It is a simple and easy-to-build project that requires only a few external components. The circuit is based on AMT49400 IC which is an advanced 3-phase, Sensorless, brushless DC (BLDC) motor driver with integrated...
