Tag: Full-Bridge
![Phase-Shifted Full-Bridge Controller with Synchronous Rectification using UCC28950 Phase-Shifted Full-Bridge Controller with Synchronous Rectification using UCC28950](https://www.electronics-lab.com/wp-content/uploads/2024/02/002-1-1024x722.jpg)
This Phase-shifted Full-Bridge controller with synchronous rectification carrier board contains all of the features necessary to implement a phase-shifted full-bridge with a synchronous rectification topology power converter. All inputs and output pins are accessible using a header...
Continue Reading![Self-Oscillating Full-Bridge Using IRS2453 Self-Oscillating Full-Bridge Using IRS2453](https://www.electronics-lab.com/wp-content/uploads/2023/08/003-2-1024x826.jpg)
This is a Self-oscillating full-bridge project built using the IRS2453 chip. This chip incorporates a high-voltage full-bridge gate driver with a front-end oscillator similar to the industry standard CMOS 555 timer. HVIC and latch-immune CMOS technologies enable ruggedized monolithic...
Continue Reading![Carrier Board for Advanced Phase-Shift PWM Controller UCC3895 Carrier Board for Advanced Phase-Shift PWM Controller UCC3895](https://www.electronics-lab.com/wp-content/uploads/2021/12/002-3-1024x618.jpg)
This is a Phase-Shifted Full-Bridge PWM UCC3895 carrier board that contains all of the features necessary to implement a phase-shifted full-bridge topology power converter. All inputs and outputs pins are accessible using a header connector. A highly-efficient DC-DC converter can be...
Continue Reading![Phase-Shifted Full-Bridge PWM Controller Module – LM5046 Breakout Board Phase-Shifted Full-Bridge PWM Controller Module – LM5046 Breakout Board](https://www.electronics-lab.com/wp-content/uploads/2021/10/002-1-1024x678.jpg)
This is a Phase-Shifted Full-Bridge PWM LM5046 carrier board that contains all of the features necessary to implement a phase-shifted full-bridge topology power converter. All inputs and outputs pins are accessible using the header connector. High efficiency DC-DC converter can be...
