Tag: H-Bridge
![3-Phase Advance Motion Module – 400VDC – 4A 3-Phase Advance Motion Module – 400VDC – 4A](https://www.electronics-lab.com/wp-content/uploads/2024/05/002-7-1024x819.jpg)
This is an advanced Motion module providing a fully featured, high-performance inverter output stage for AC induction, BLDC and PMSM motors such as refrigerators, fans, and pumps. This module is based on NFA50460 chip which integrates the optimized gate drive of the built−in IGBTs...
Continue Reading![H-Bridge for High Power Brushed DC Motor with Current Sense H-Bridge for High Power Brushed DC Motor with Current Sense](https://www.electronics-lab.com/wp-content/uploads/2024/01/006-8-1024x745.jpg)
This H-bridge board is an easy-to-use brushed DC motor driver that can handle large-size motors such as wheelchair motors, and winch motors. An H-bridge is an electronic circuit that switches the polarity of a voltage applied to a load. The circuit is built using 4 x N-Channel...
Continue Reading![Position and Speed Controller for DC Motor with Incremental Encoder Position and Speed Controller for DC Motor with Incremental Encoder](https://www.electronics-lab.com/wp-content/uploads/2024/01/005-7-1024x915.jpg)
This project consists of Arduino Arduino-compatible microcontroller ATmega328, an L298 Motor driver, a Joystick, a programming connector, an Infrared sensor, and various analog and digital I/O pins. The project is Arduino compatible and can be programmed using Arduino IDE and many...
Continue Reading![DC Motor Control Using Joystick DC Motor Control Using Joystick](https://www.electronics-lab.com/wp-content/uploads/2023/10/001-1-1024x717.jpg)
This is a compact, low-profile, and high-performance DC motor driver that provides easy control of a DC motor using a joystick. This small-size board can drive small to medium-sized brushed DC motors with up to 2.5A continuous and 6A peak currents. It is an Arduino-compatible project...
Continue Reading![DC Motor Position Control Using Potentiometer – Arduino Compatible DC Motor Position Control Using Potentiometer – Arduino Compatible](https://www.electronics-lab.com/wp-content/uploads/2023/08/002-2-1024x852.jpg)
The project presented here is an Arduino-compatible motor control board. The board consists of an ATMEGA328 microcontroller, LMD18201 H-Bridge, and 2 x potentiometers. This closed-loop servo system provides position control using a feedback potentiometer mounted on the output shaft of...
Continue Reading![50V – 5A DC Brush Motor Driver – High Performance, High Reliability 50V – 5A DC Brush Motor Driver – High Performance, High Reliability](https://www.electronics-lab.com/wp-content/uploads/2023/04/002-6-1024x649.jpg)
This is a powerful yet small-size and low-profile brushed DC motor drive system, with key features like adjustable constant current control, direction control, brake controls, Alert output, PWM for speed control, etc. The BD63150AFM chip is the heart of the project which is one...
Continue Reading![High Performance – High Reliability 50V DC Brush Motor Driver High Performance – High Reliability 50V DC Brush Motor Driver](https://www.electronics-lab.com/wp-content/uploads/2022/07/002-3-1024x771.jpg)
This is a powerful yet small size low profile brushed DC motor drive system with a few key features like adjustable constant current control, direction control, brake controls, Alert output, PWM for speed control etc. BD63130AFM chip is the heart of the project which is an H-bridge...
Continue Reading![DC Motor Controller using Relay and MOSFET – Arduino Interface DC Motor Controller using Relay and MOSFET – Arduino Interface](https://www.electronics-lab.com/wp-content/uploads/2022/01/005-3-1024x808.jpg)
The project presented here is a low-cost solution to control high power brushed DC motor speed and direction. Traditional DC motor controllers are based on solid-state circuitry known as H-Bridge. Here we have made an H-bridge configuration using high current 2 x relays which can...
