Tag: Hall-effect
![Signal Conditioning Module for Magnetic Rotary Encoder with Clock and Up/Down Direction Signal Output Signal Conditioning Module for Magnetic Rotary Encoder with Clock and Up/Down Direction Signal Output](https://www.electronics-lab.com/wp-content/uploads/2023/05/002-5-1024x624.jpg)
This is a highly sensitive, temperature-stable magnetic sensing module ideal for use in ring magnet-based, speed, and direction systems located in harsh automotive and industrial environments. The module is a complete solution to make a magnet-based rotary encoder, which provides...
Continue Reading![3 Phase Isolated Hall-effect Current Sense Amplifier with +/-600V Working Voltage and +/-46A Measurement Range 3 Phase Isolated Hall-effect Current Sense Amplifier with +/-600V Working Voltage and +/-46A Measurement Range](https://www.electronics-lab.com/wp-content/uploads/2021/04/001-4-1024x755.jpg)
The project described here is a 3-Phase isolated Hall-effect current sense amplifier with +/-600-V working voltage range. The current sensor senses magnetic flux generated from current passing through the lead frame at common-mode voltages 0 to 600V DC and provides proportional output...
Continue Reading![High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002 High Accuracy Current Sensor with 400Khz Bandwidth using ACS37002](https://www.electronics-lab.com/wp-content/uploads/2021/01/004-1024x800.jpg)
This is a high accuracy current sensor project build using ACS37002 IC from Allegro, which is a fully integrated Hall-effect current sensor with 0.85mOhms integrated conductor. A fast overcurrent alert output, programmable gain settings and analog linear voltage outputs are key...
Continue Reading![MC33035 Brushless motor driver breakout board MC33035 Brushless motor driver breakout board](https://www.electronics-lab.com/wp-content/uploads/2018/02/IMG_1455-scaled-1024x698.jpg)
The board shown here is a breakout board for MC33035 brushless motor controller. It requires an output buffer IPM module or MOSFETs to complete a closed-loop brushless motor driver circuit. MC33035 IC is the heart of the project. The board provides 6 PWM pulses as well as 6 Inverse...
Continue Reading![Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder Dual-Channel Quadrature Hall-Effect Bipolar Switch Module for Magnetic Encoder](https://www.electronics-lab.com/wp-content/uploads/2017/01/Hall-Effect-Bipolar-Switch-PIC1.jpg)
The A1230 is a dual-channel, bipolar switch with two Hall-effect sensing elements, each providing a separate digital output for speed and direction signal processing capability. The Hall elements are photo lithographically aligned to better than 1 µm. maintaining accurate mechanical...
